"playback failed because Roon couldn't connect to HQPlayer"
Hi guys. I believe that I have done all the forum searches both here and on Roon, including following @MarkCole instructions posted - yet I still get the above error.
I understand the 30min thing and also have set up a test library (thanks for the tip @kennyb123 ). Here is the HQPlayer setup on my K30:
On Roon I have tried both IP and Localhost.
Suggestions gratefully accepted…
What does the AMS Dashboard look like?
Hi @MarkCole, do you have any thoughts that may help here please?
The support team will need to have a look, please book a support session
Maybe stating the obvious but have you added a HQplayer under your Roon settings?
Sure did Mark. Just finished a support session a few minutes ago and now all good. Thanks for your reply.
