Hi There,
Just a quick rookie question
I’ve just purchased and installed S30/S60 combo.
Do I leave S60 power always on or is it better to turn it off using power switch on the back panel after each use?
Hi There,
Leaving it on is what Antipodes recommends. I recommend leaving digital gear always on. Thermal stabilization is best for sound quality.
Thank you for reply mate, will do so.
Yes, my k50 is left fully powered up 24/7, as is my Dave and Mscaler.
Digital components should deliver a shock to the person who’s trying to power them down. Or at least a warning like “Do you really want to harm sound quality by powering me down?”
I obviously leave mine on because it improves the sound quality, but I’d also advise usage/installation of adequate surge protections devices. A type 1 or 2 SPD should ideally be installed at the incoming mains position (dependant on supply arrangements) with type 3 SPD’s plugged in adjacent socket outlets to those powering your system. This will have no detrimental effect on sound quality as they connect in parallel rather than in series & are passive except in the event of a surge or spike. For the installation at the mains position you should consult a qualified electrical installer. However, this should not be an expensive job as the actual SPD’s themselves are quite cheap. Subject to a spare way they can often be installed in the same consumer unit/fuse-board.
