Problems with Squeeze Player
Hello,
I am running a K21 as a player and a K41 as a server. The server and player are currently running Roon. The audio output is USB Amanero to my Linnenberg Satie DAC. I have now set Squeeze Player and Roon Server as the playback method in the K21. The audio output remains USB Amanero.
When I open my tablet and try to play music, the Linnenberg DAC has disappeared. I get the message: No audio devices found. What am I doing wrong? I would be grateful for your help.
Regards, Kurt
Under Audio settings you must make sure that an output in the following section is enabled. If it is enabled switch to it in Roon.
If you don’t see an output in the following section, make sure Squeeze server is not running. Also makes sure Enable Squeezebox support is turned on in Roon settings under Setup.
Oddly the following output didn’t appear for me until after restarting Roon.
Hello Kenny,
thank you very much for your help. I followed your instructions and now I got it. For the next days I will see what sounds better Squeeze or Roon. And now good night. It‘s time to go to bed in Europe.
Kind regards
Kurt
