Qobuz with Squeeze Player and Squeeze Server without Roon
Hello everyone,
I want to play files from Cobuz with Squeeze Player and Squeeze Server without Roon. On oladra Is this possible and how? Thanks for the help.
Find the Qobuz plugin in the list and enable and sign in. You should be good to go.
You need to configure oladra with squeeze player and squeeze server. Wait for the squeeze service to start (wait a few minutes). On the oladra dashboard, click enter squeeze configuration, and another page will open in your browser. In the top right, select server for configuration. In the server configuration menus, search for qobuz and enter your username and password. Everything should be fine.
Hi, thanks for the response.
I can’t access the Squeeze menu. I get a message that the page is not found.
You have to wait some minutes.
The squeeze service is not so quick to start.
?More than 10 minutes
Make sure that Roon is not enabled as Server at same time as Squeeze.
Ten minutes is too long. Reboot.
Roon’s server is closed.
Rebooting didn’t help either, I think I’m giving up.
In the player section start with choosing Squeeze. Then in the server section choose ‘server app’ next to the Squeeze logo.
This should open the Squeeze homepage. Here you must find ‘apps’. This opens a list or some tiles with different apps amongst which you will probably find Qobuz. Choose Qobuz or the 3 dots next to Qobuz (to pin Qobuz to the Squeeze homepage).
When starting Qobuz the first time remember to log in. All set.
When selecting Qobuz Server, aps does not open.
Firewall or other things ?
Maybe
I tried everything I could.
Perhaps ask Antipodes for a remote session
Squeezeplayer with Ron Sarver is working
If you selected squeeze as the player and squeeze as the server, the service should start.
Good news today I received remote support from Antifodis and everything is working thank you very much everyone
Great news my friend.
Antipodes support very good in just few days.
They hired someone new?
