Hello, my name is Jürgen.
I use Tidal with my S30, no Roon.
Is it possible to use Airplay ?
or is there Another, simple Way to catch Music Files from YouTube with the S30?
Thanks and Best regards!
Jürgen
Jürgen
I would’nt think so, best to use some kind of airplay receiver like a smart tv or an apple tv into a preamp
I believe the Shairport playback method provides the way to do this. Enable it in your dashboard and you should see your S30 appear as an AirPort target.
My mistake as I still see the option in my v5.0.1 dashboard. I didn’t try it though.
DOH, Indeed, Shairport is still an option in AMS, I defer to the expert ![]()
