Hello all together!
It is extremly difficult to start the S30.
First my Handy often demands to change airplay-functions - I tested all options - then I have switch off my iPhone 11, then often I have to wait many minutes, till the renderer accept commands.
Can somebody help???
How many Watt the S30 + S60 need in continuos function?
Is it harmful to use it in continuos function?
The S30 + S60 sounds very very good, but main thing is that it works solid.
Logitech don t work, so I have to use MPD Pilot and MConnect as apps.Are the apps part of my problems?
OK, Germany is developing country on digitalization.Me too…
Very frustrating! To much problems. It can t be a solution to use the CD-Player as a safer option.
I used an Innuos server a few years ago… no problems… but it sounded worse :-)…
I wish Antipodes would install much much more software for simplifying using the server.
At the end of the day I want to hear music, I spendend many many many many hours in starting and using the server, contacting my dealer 15 times. Are Antipodes Server just for technic and digital affins?
Best regards! Jürgen
