S40/Roon/Tidal glitch
Dear all, I’m not able to stream Tidal by my system (s40\s30) with roon anymore. It ist Just one glitch, a complete mess. First it happend once a while but now it is constant glitch. The Internet works fine and I can stream from the internal SD Card without Problems. I already rebooted everything etc, etc, etc. I’m starting to regret the huge Investment, since the set Up seems to have constantly some sensitive issues. At least since I added the S40.
Or Maybe i have to Switch to qobuz.
Roon is third party software. Your best bet for finding help is to search the Roon forums or post there.
You can always book a support session for the team to check your music server configuration, here to help as best we can, however, as mentioned, Tidal inside of Roon isn’t something we have control over.
You can also check that your router configuration is as per Roon:
Also, Roon likes to have good DNS such as Google or Cloudflare:
Dear Mark, thank you for your Support. I’ll also contact cm audio. There May be a Hardware Problem. It is now, little Like a loose contact. Sometimes Roon recognizes the Server the next time Not. In the Antipodes App i can Always See the S40. Maybe IT IS trivial Like the Switch or cabel connection. The Last Time IT was an issues because of the IP Adresses (as O understood).
Thanks again
Jürgen
You are leaving the servers on all the time? Or are you turning them off?
