I’m going to be upgrading my EVO SSD to PM893 in my K41 for my music storage.
My library is 2.0tb. What is the best way to clone the new drive?
I don’t want to say anything incorrect, but unfortunately, you’ll need to copy your current 2TB drive to another external drive (not the PM893)…Then, you delete the current storage from your Antipodes (you go to “manage disks” on the Dashboard)…
You install your PM 893… the Antipodes will format it, and only then will you be able to copy your files from the external backup you created.
The process requires 3 drives…
Personally, I wasn’t able to copy from one drive to the other when both drives were inserted into the Antipodes.
Mark can correct me if I’m talking nonsense. ![]()
Not nonsence ![]()
Everyone should have a music library backup.
The easiest way is removing the old drive, replace with new, and copy the new library across over the network.
Yep, that’s exactly what I did. Simple and seamless.
