Hello, using Squeeze server + SqueezeLite player. Since a few weeks I seem unable to run a search in the material skin mode (as seen below the app gets stuck in search mode without any results). It works fine on iPeng
Any ideas?
Any ideas?
I usually search within the Qobuz plugin, but I tried this and it’s the same for me, just sticks in search mode.
Thanks - I do the same now. But this was working a couple of months back. The annoying thing is that I cannot search my own albums by keywords anymore.
Can you advise what browser you are using please.
Hi Mark, I have the same behavior on: iPhone (OS), Chrome and Safari (on Mac). Albeit not 100% sure I am fairly confident this started after a software upgrade.
Search works OK on either iPeng or “classic” skin
Hi there, indeed search is broken in Squeeze, we are pointing our developer at the issue
Thanks Mark. I am now sure it will be soon fixed! Keep us posted
