Hi all, my S30/S60 combo is rock solid, ticks along without issue driving Roon with an external DAC. It appears in my network as a location, I can copy files back and forth, and there seems to be nothing wrong with how it’s configured, but I can’t access the dashboard via the antipodes URL like I used to. I just happened to be trying another DAC this week, and wanted to check through my settings as I was having an issue (which turned out to be preamp related), and I can see the S30 on my network, via my modem/switch and the website at the static IP assigned, which is recognised by antipodes.audio/setup.php - but when I click the “open” button, I get http://192.168.124.6/v4_solutiondash.php, and the “no internet” screen in my browser.
I figure this is something simple i’m not grasping here! Any ideas? Thanks!
Yes you are trying to access your Antipodes over the web browser, but from what kind of device? Mac? PC? iPhone?
The reason I ask is that I have found that best approach to solve problems like this is the process of the elimination. I first like to eliminate whether a configuration issue exists on the device used to browse to Antipodes dashboard.
ah, sorry, I mis-interpreted your question! Thank you for responding because it made me think out loud, and I’m using Brave Browser as my default, just tried with Safari and it’s perfectly fine. So thank you, you solved my problem for me! much appreciated!
