SpotOn for Spotify Connect - issues
[Please direct me if this has already been discussed :slight_smile: ]
I have switched from ‘Spotty’ to ‘SpotOn’
I have an API Key from Spotify, so should be able to use SpotOns backend “Soloist” (which should let me access Spotify lossless. )
However, I get this error message : glibc_too_old:glibc_2.38
So if I am understanding this correctly, Spotify’s Soloist program requires a newer Linux system library (glibc 2.38 or higher). The current Antipodes AMS 5 does not support this, so I cannot use Soloist.
The reason I am trying is because Spotty has stopped working, and SpotOn (using “Librespot” ) does not recognise files via Spotify Connect, and rapidly skips through playlists. I.e. is not working.
If any of this is familiar to anyone, your thoughts would be much appreciated.
