Squeeze, hqplayer, jplay, roon all to the same endpoint and able to play to 768
An exciting development for my use case for pggb playback of pcm files. You may have heard hqplayer v6 has a upnp stack. I usually use jplay or roon through hqplayer (bp) for playback. Right away I thought it would be great to add squeeze server to that so all my software could playback to the same endpoint. I loaded up the upnp bridge plugin in lms/lyrion. Unfortunately everything over 384k was converted to 44.1. On a whim I took a chance and approached the author Philippe44. Although it was never asked for before he was willing to give it a go. After many changes and log exchanges it works. He is not happy with the workaround and has proposed a change to lyrion which has been accepted. Now it may be expectation bias but as with squeezelite direct I feel it sounds better than roon and equal to jplay.
Re: Antipodes… the proposed core change will only be for future versions so I hope Antipodes is able to provide an upgrade path soon.
Really awesome move to reach out to that developer. It would be very nice to have that capability, especially in light of an update to PGGB that will be coming in the not too distant future. :grinning:
OMG……… competition fir Quartet
Hmmm… That would be on the fly upsampling, yes? And do I see DSD options there?
Yes and yes. I was able to stream up to DSD256 to MPD on Antipodes.
Sharing as an FYI. I have no affiliation.
https://audiophilestyle.com/forums/topic/72148-lyrion-lms-upnp-player-plugin-for-jplay-ios-looking-for-beta-testers/
Another development- Hqplayer Bridge,
https://forums.lyrion.org/forum/user-forums/3rd-party-software/1834963-announce-hqplayer-bridge
Works much better than UPNP Bridge and allows squeezeDSP to work properly.
