Has anyone else had Squeeze display like this, with big link descriptions appearing where they shouldn’t? I have tried the usual restarts of everything, switching server/player apps, and deleted cache. I am on AMSv4.31. It is not stopping the music.
Hi, yes I’ve seen this when the remote device has enlarged font enabled.
What is the device?
Good morning Mark. It is an i7 Asus laptop (probably 10 years old now), running Windows 10
Which browser were you using?
I use Google Chrome.
Thanks Mark. I will check tonight.
Not yet resolved with this or other display settings I could find. Thankfully this is not affecting sounds, but just makes it a bit challenging to navigate.
I should mention that the text in question is not normally displayed at all. I,e, it is not resizing text that should be there, but it is actually displaying some background labels of links that are never intended to be seen at all.
I tried switching to Edge and Firefox and then tried another W10 Desktop PC.
All display the same issue.
Could Squeeze have been updated over the last 2 weeks? (I have been away for nearly two weeks and this was only discovered on my return).
Hiya, make an appointment for remote support, we can take a look for you ![]()
Remote support session booked. Thanks Mark.
Edit. Sorted. Awesome service as always thanks team Antipodes. Perhaps I’m just imagining it from Prince’s 4.4 upgrades … but ye gods it sounds good tonight ![]()
