Has anyone else noticed the vast array of plugins available is Squeeze has disappeared? I went to use Bandcamp and it’s disappeared from my apps and I can’t see it in the Squeeze screen either
Hi Mark, I used to see the same as your screengrab but now all I get is this
I’ve tried on my Mac as well, exactly the same. I go solution > server > squeeze to get to this
Looks like you are in the Player, not Server
Found it! Thanks Mark
For a long time now, the server section does not appear at all. What can I do to fix it?
Fedor Friedman
Yes, I’ve done that several times, to no avail.
I think I found it by going to Library, then extra settings
I don’t know where to look…
Please clear your browser cache, also are you using a bookmarked shortcut, try directly from AMS to launch Squeeze after the browser cache clears, failing that book a session:
Please book a remote support session here:
