Squeeze / Squeeze tracks skipping
Kia ora te whanau
I have a K50 G4 usage squeeze / squeeze. I’m mainly streaming Qobuz along with some local files.
If I pause a track in Qobuz, and then restart 5, 20, 180 seconds later ( the elapsed time doesn’t seem to matter) the track being played jumps to the next on the playlist or album.
The issue happens less often if I’m only 30-40 seconds into a track, but not even then it still happens.
This scenario is a pain in the xxxx when I pause music to take a phone call or have other interruptions.
This behaviour doesn’t happen with local files, and I’ve tried changing buffer size and other parameters, but nothing seems to work.
Any thoughts anyone?
Cheers
Hiya wlgmuzza, please book a support session so the team can check it out for you.
