Anyone else having issues with Tidal ? I try to play tidal tracks on my LMS and it skips over the Tidal tracks in the queue . Seems to play my Tidal playlists, but if I select an artist and play I get N/A.
Try restarting Squeeze. If the problem persists, try restarting your router. If that doesn’t solve it, odds are that it’s a backend issue that will be resolved within a few days.
When you say restart Squeeze you mean the restart in the server section of LMS ?. I will try and restart my modem
Restart both server and player. Choose a different playback method and then switch back to Squeeze should do it (assuming you haven’t locked Squeeze).
Edit: - After rebooting everything I tried once more to delete the Tidal account and then re-link the Tidal account. Seems to be working for now.
I restarted everything. Still the same issue. Tidal might play a random track here & there. If I select a playlist it usually skips the 1st song, and might skip other songs. If I search an Artist it will not play. Skips 1st song then stops on 2nd song without playing.
Also I noticed where the information on track playback like VBR 16bit 44.1KHz FLC it displays N/A.
If I can’t resolve this I’m going to have to end my Tidal subscription. That’s too bad.
