Tidal seems to be stuck in 320kbps MP4 even though settings is for lossless
Having trouble with Tidal playing lossles and HiRez lately.
It seems to be stuck only in 320kbps wven the settingbis for CD FLAC. And Hi Tez setting seems to be no longer available in the plug-in.
I have confirmed thag my Tidal is for Hi Rez on my mojile.phone and plays Hi Rez on the phone.
I have uninstall the Tidal Plug-in in the Squeeze server and reinstall. Problem remains.
Anyone else seeing this issue?
Help!
This is a known issue on the Lyrion forums. No so,ution at present. Something about how the plugin presents itself to Tidal. Still works on roon and Jplay.
An update from Lyrion.
v1.8.1 might address the FLAC issue. I’ve only been testing it for about an hour… You’ll have to re-authenticate after installation.
I’ve installed and tested. It brings you CD quality at least.
@Progisus can you talk me through the update process on an Antipodes streamer server?
Hi Nick, @NickBacon
Manage your plugins.
Tidal should be 1.8.1
Restart
Go back to manage plugins and Tidal
Logout
Restart
Re add your account and set for CD quality
Restart
Should now get at least CD quality
Hope this helps
  • probably more restarts than necessay
I had 320 also and advised as per the info from Lyrion forum.
Now at CD quality on Tidal Local or v1.8.1
If you do not have v1.8.1 or are having problems installing it, please book a remote session and the team can update the plugin from 1.5.1 to 1.8.1
Note, the remote support booking process has changed over to Circle our “User Hub”
If you havent already, create an accout and register your device on Circle and click “Assistance” and follow the instructions for booking a remote support session.
Confirm that Tidal 1.8.1 shows up on my server. Added it and signed onto my account and now can have 16/44.1 FLAC. Not sure about Hi Red though. Will check
Ok. Tried some 24/96 Tidal files but it only streams at 16/44.1. So High Res on Tidal is still out.
I am having the same problem. Anyone knows when it will be resolved?
Check my post a few up for a fix. This will give cd quality. The Lyrion forum is looking for a hirez fix but doubtful anything will happen soon.
Will try. Thanks a lot for the tips.
