Two box solution Server not found
I have a two box solution with EX as player and CX as server. Until recently it was working fine. At the moment both the EX and CX are found on my network. However, I can’t seem to access the CX as the SERVER DEVICE in my dashboard on the EX (see drill down menu). I booked a support session for next Friday but just maybe someone is familiar with this issue.
I had a problem with Roon and they fixed it for me yesterday. Can you use other solutions besides Roon? If so, I think they’ll fix it with a remote session. It seems that perhaps a Roon update is causing the problem.
Good luck
Hi Jorge, I can use squeeze at the moment so for now ok. I hope we can fix this on my scheduled support session . Thx for now.
So now it partly works. My CX is functioning as server, although I cannot choose it as server in the dropdownmenu. Instead I choose ‘disable server’ and started Roon server on the separate CX dashboard. It works but not as intended. Ok for now.
