Upgrading AMSv3.1
Also wanted to add my thanks to @MarkCole for the work he did with logging into my system and talking me through some issues I had after the update - we’re these specific to Antipodes or a glitch with Roon, hard to say, but Mark was first class in his service and my K40 / Roon is working smoothly now :grinning:
Kudos to you @MarkCole , and to Antipodes for the gargantuan process of getting everyone on AMSv3.1, that will enable smoother updates in the future :+1:
@MarkCole is the man!
He helped me tonight get my old Edge upgraded to 3.1, it was a long nerve racking process but it was a success.
Now a bit of advice.
When it asks you to reboot in between stages 1,2 and 3 do NOT rely on the GUI reboot, this would not let each next stage proceed for myself.
A hard actual physical reboot of the unit was required and then it would proceed.
End result is that I now have the latest Roon build 846 and it sounds spectacular.
Hats off to the complete Antipodes team.
Well done indeed and thank you
Yeah, Mark helped me out too. The support the Antipodes team provides is truly incredible. When you’re lost, I can’t imagine anyone doing better to get you back on track. Thank You !
AMS3.1 (once installed) seems to be a triumph! Very happy with the results and have completed a total of 6 upgrades to various units. I did have a CX stall after completing Stage2. What appears to have happened is, upon rebooting after Stage2 completion, the network card did not fire up (or some other part of the motherboard) as was indicated by no visible activity at the Ethernet port.
Me being terribly impatient, I decided I would just reboot again (worst case scenario, I just reload the OS–which is in fact a procedure!)…and the second attempt worked without further issue. That was the worst of it. Perhaps @MarkCole can chime in and recommend taking the same steps–or not!–if your unit stalls after Stage2
I had exactly the same and what I found to be the solution was an actual hard physical reboot, the software reboot through the GUI did not cut it.
Not sure if this works for anybody else but it did for me and then roaring onto success!
Antipodes is actually pretty clear in the instructions that the reboot must happen from the front panel power button (never the rear!!!) and not from the web GUI. Why, I don’t know, but it’s clear that rebooting from the web GUI is not recommended
Hold on…instructions?
We are supposed to read instructions??
Lol, yes you are of course correct once I actually reread them, my brain obviously skipped over that part… :thinking:
That’s ok, I read the instructions many times only to find out there were a few initial steps missing :wink: But Mr. Cole has been working incredibly hard to rectify things.
Forgot to turn off the Roon auto download.
So I had to update the system anyways.
Went smoothly with mine S40.
Also just needed to make sure to restart the server manually after every stage.
I think it could have been even more clear on the update stage.
Like a
Stage 1 completed
*Reboot ONLY with FRONT STANDBY BUTTON of your Server *
That would probably be super clear.
After a reboot, my CX has the latest update, and EX constantly beeps and I can’t go into its settings.
@roman
Please contact support@antipodes.audio
Thanks for everyone’s patience. There is a lot going on at present, but I will try to be concise.
We can see from our database that more than a thousand users upgraded in the first few days, and amongst that we were always going to have a few failures, given that we needed two kernel downloads over the internet to work without a hitch. This is no consolation if you are one of those that struck a problem, and you are our top priority right now, but the failure rate has been very low.
While Mark Cole has been the point person for all of you, three of us are working in the background, getting reports from Mark about what is going wrong for some users, feeding Mark with fixes where they can be simply applied, and/or developing patches for the next push.
The next push will include updated third party apps, upgrades to the myantipodes process, a couple of bug fixes, and a new Squeeze remote control web app. We have a large software development program underway, but the critical first step is getting users onto a common v3.1 starting point.
I think it is worth clarifying a couple of messages that it seems we have not communicated well enough. The first is about the need for patience with the upgrade steps, and the second is about how overnight updates work.
The need for patience.
The upgrade steps include downloading and installing a new kernel for the operating system. A new operating system needs to interrogate all hardware components on the main board and some connected boards, and then configure its device drivers to ensure that everything will run as it is intended. For example, the same kernel is being installed on a DS1 from 2011 and a K50 from 2021 and every motherboard we have used in the decade between those. The differences in drivers required have to be determined and configured for each music server. This happens the first time you boot into the new kernel, and that process has a set time limit of a couple of minutes. The time limit is necessary because, in our experience, users often panic at a long boot and pull the plug, potentially causing a more serious problem.
So you might not get a completed configuration at the first boot after Step 3/3. So another reboot or more may be needed to get everything configured properly, depending on the quality of your internet connection. A number of factors will affect how long it takes to get the job done. I think we had a dozen or so reported upgrade failures that resolved themselves after as many as four reboots. I have only touched on one of the reasons why this is not a simple ‘press a button and it is done’ kind of process, but it might help you to understand that the system needs to be given time to sort itself out, and this is normal.
Overnight Updates.
Prior to v3.0, we did not have a way to push updates out automatically. Customers had to initiate the updates, which led to our many customers being on a range of different generations of operating system and applications. This makes it very difficult to provide support and ongoing software upgrades.
Nor were we in a position to do anything about that without getting the update code onto your devices. We did manage to get the code out to a few devices with an update in 2019, but not many customers took up that offer. All v.3 devices have the update code. So this v3.1 upgrade process is flushing out who still needs the update code and Mark Cole is progressively getting it out there.
In some cases poorly setup IPv6 configurations on DNS servers managed by your ISPs are also getting in the way of the update code being able to work. Fortunately this is impacting only a small percentage of users, but we are giving them top priority at the moment. Changing your DNS server addresses and/or disabling IPv6 on your router is typically going to be needed to fix these ones, as the problem has nothing to do with our code. Sadly these problems are not uncommon when a new internet standard is rolled out - if you can browse the internet and send emails, then that is sometimes all your ISP tests for when implementing on their DNS servers. It eventually works itself out and right now IPv6 implementations are creating problems for a wide range of software that requires sophisticated communications. In our case, the fault does not lie with our software, it lies with a small number of ISPs.
Once we have actions underway for all customers that need a fix, we will shift our focus to the ongoing overnight updates, to push out new versions of apps, bug fixes, enhancements, etc. We do not want to interrupt your listening pleasure, so these updates are timed for around 3:30am. To receive the update your device needs to be booted up and left on overnight.
If you like, just do this once a week or once a month, but if you want the optimum sound quality from your Antipodes music server you should typically be leaving it always on anyway. At 3.30am, your device will look at the Antipodes repository and check that it is up to date. If it sees that there are later versions of any software components it will download and install them. Sometimes an internet issue will mean your device is timed out from the repository and you will get the update on another night.
We only add new software components to the repository when they have been fully tested on our operating system and with our integration code. We do not put a new app in the repository just because the third-party software developer has a newer version, because that risks your server receiving a version that will not work on your device. The only exception to this is Roon, where our partnership with Roon means there are processes in place to ensure their new versions will work before they are released.
Sorry for the long post, just hoping it clarifies a few things.
@antipodes many thanks for that informative post which is much appreciated and I look forward to all the planned things over the next months and years. As well as any technical improvements in 3.1 the user interface is now really easy to use and is much better.
Mark Cole has been at the sharp end of the update process and he has been an absolute credit to Antipodes. I doubt he has been to bed during the whole time.
One thing which you may or may not know is that after the 3.1 upgrade some of us are already now on different release versions of some of the apps supplied with 3.1 (we talk to each other :grinning:). So perhaps an early push can just rectify that? If it would be useful I can supply details of which different versions of the apps have been sent out with 3.1 but you probably know anyway.
Thanks again for all the huge effort from you guys at Antipodes which is bearing fruit.
Many thanks for ALL of the hard work your team has been doing on this and huge thank you to your point man @MarkCole .
Without his personal touch I would have been scuppered!
I am a very happy user as I was convinced that my older Edge was going to be left out in the cold but you guys have proven to myself how customer service should be in this age.
I told Mark that I was going to buy a S30 later and that is still going to happen but I am so impressed that you got my Edge into the modern world with v3.1.
Congratulations to the Antipodes team.
Congrats to the entire Antipodes team and special shout out for @markcole for all of diligence and paitence demonstrated with all the past week.
My install (Dx3) was painless and error free. The instructions provided were well written & excellent. The minor issue issue I had Mark was able to resolve in 30 seconds. (authorizing t new core)
Thanks to the entire Antipodes team. Best damn support in the industry!
How do I get the upgrade to 3.1 was away this week. Not sure I understand the clock time setting ? So again how do I get the 3.1 upgrade sent to me thanks Eli
As per previous post
@ELI1333
Remote Support Instructions
Please follow the instructions above for remote access support
I take it I make a 1 on 1 appointment ?
@ELI1333
As per instruction, please send me your Anydesk ID to support@Antipodes.audio
This is preferred.
Hi, i just bought a CX from Elite audio, i am in the UK.
How do i get the AMS 3.1 firmware?
@MarkCole All is setup for roonserver, i have installed Plex server too but it wont open the plex GUI when i click on the icon?
Regards,
Raj
