Upgrading to AMSv4.0: no more sound
Sounds like a USB problem, if you plug your USB cable to your DAC into one of the other USBs on the back of the S30 do you get sound?
And/or swap out the USB cable, just to rule that out.
I really don’t think it is the cable, given that it worked on Friday but on Saturday after the upgrade it didn’t.
I thought the other USB ports on the back were for connecting HDDs etc. Can they also be used to send signals to the DAC? I’ll give that a try. But I don’t think I have another USB cable with a USB-A terminator and the one I am using is a) less than a year old and I had the impression that Audioquest cables were reasonably high quality.
Just try and see if sound is output via one of the other rear USB’s
BINGO! that works, using one of the other USB ports with the same cable.
I am as I type playing Miles Davis’s Mademoiselle Mabry in DSD64…
Thanks for you help, I am once again a happy camper.
Brilliant, fabbo :+1: :grinning:
And later on played the Dragon Quartet’s Schubert ā€œDeath and the Maidenā€ at DSD256.
Life is good, or it would be if I didn’t have to leave for the dentist in 25 minutes…
