What is required to play HQPlayer DSD (SDM) files over an AQLink connection Aqua La Scala DAC and K50
I have ordered an Tubulus Concentus I2S/RJ45 cable to use the I2S connection between a K 50 and an Aqua La Scala DAC. I use HQPlayer with Roon Server and can play PCM files but no DSD (SDM) files.
Has anybody experiences with that configuration and the same „problem“? DSD with an USB connection works very well.
Thanks for your Support in advance.
It’s my understanding that the DIP switches need to be properly configured in order to play DSD over I2S. Have a look at this thread:
Hello Kenny,
thanks for your answer. I can play PCM files very well. The Tubulus Concentus ( special cofiguration - Marks information about the pin connection) is a very good cable. There is only a marginal difference to an 4K cable from JPS Labs. I believe I have made the correct setting in HQ Player. The setting SDM -PCM conversion transfers DSD files over DoP to my La Scala DAC. I have a good sound and there is nothing more to do. But thank you very much for your explainations. Have a Merry Christmas and a Happy New Year. ( I have to excuse me for my Bad English)
Günter
