White noise trying to play DSD file from Oladra to Lampizator Horizon 1
I am using either the HDMI or RJ45 i2S connection from my Oladra to the Lampizator Horizon 1 (old model) but I get white noise while trying to play DSD files. PCM is fine. What am I doing wrong ? I am guessing I need to change the positions of the toggle (DIP) switches at the bottom of the chassis of the Oladra unit. Need your kind assistance to provide some advice on the configuration. Much appeciated.
Joe
Hi there, I would use HDMI, see the master thread below:
The Horizon manual is a bit scant on information; however, it appears that the Horizon also uses PSAudio config, can this be confirmed by Lampizator
