Is there any plan to be able to use Qobuz Connect with Antipodes?
https://help.qobuz.com/en/articles/314578-list-of-brands-integrated-into-qobuz-connect
Thank you in advance for your input.
Kind Regards,
David
Kind Regards,
David
Hi there, Antipodes Audio is a QOBUZ Partner, and we anticipate including QOBUZ Connect in our software. The software project is ongoing, release is yet to be determined.
Spotify Connect would also be nice too ![]()
Spotify Connect is available via Squeeze plugin currently, but understand what you mean however.
Thanks Mark. Not essential but just an alternative to be able to access Spotify in the Spotify app.
If you can believe the hype, and it seems to be universally positive, I can’t wait.
No pressure ![]()
Could be a dumb question - how do you deal with Tidal Connect? Note I used Roon so am not likely to try it, but people talk about Tidal (and maybe now Qobuz) as having better SQ than Roon, so it would be good to test and compare. I tried playing Qobuz and Tidal versions of the same track through my Roon set up which seemed to make zero SQ difference, but with Roon handling it, I am not 100% sure that it was sourcing the stream from different places (given internet comments, it should seem that I should be able to hear a difference in SQ).
