Hi all,
I have moved into a new home that does not have a wired ethernet connection in the room my system will be housed in. I am curious if anyone has explored any of the wireless client devices available on market? Or has thoughts on how to network enable the K50 without a wired connection in the room?
Thanks!!!
I ran a 20 metre CAT 6 cable under the house from my modem and then on the floor around the edges of the walls of the concrete slab room my hi-fi is in. Works perfectly.
I have mesh wi-fi (basically you can have as many wi-fi access points (nodes) as you like with a single ID). The TP-Link units I use have ethernet sockets so easy to hard-wire your K50 to a rock solid wi-fi connection.
That gets you sound, to get music power the node with a low noise power supply, ground it to a grounding box and choose your ethernet cable with care. PS and grounding on the router help too.
I am currently using the BrosTrend from Amazon with good results.
