AMSv4.2 was released 6pm 14 December 2022 NZ time (UTC+13Hrs). AMSv4.2 includes updates for HQPlayer Server and Spotify Connect, and patches to speed up the recognition of connected audio devices and to display CPU temperature for the EX.
Users with AMSv4.1 will see an update button at the solution dashboard, and all you need to do is click on it to run the update, and then reboot into AMSv4.2.
If you have a 2 computer device such as a K50, update the server first, reboot, update the player and reboot.
All done.
HQPlayer users will need to go to the server tab in the solution dashboard and restart HQPlayer server, and check the Network Backend and other HQPlayer Settings
