Probably. I tend not to refer to documentation unless I can’t figure out what something does. This one seemed pretty straightforward. I try to backup my configuration once I land on settings I like.
That’s good feedback for Antipodes. They could probably script the steps of backing up and then restoring the configuration as part of upgrading HQPlayer (or any of the apps). But I’d rather that they work on things that improve sound quality.
We quite clearly stated in the release notes that there was an HQPlayer server update.
Your licence is with Signalyst, just as your Roon licence is with Roon, and Minim with Minim etc, we have no control of the licence.
I hear what you are saying, however in the current form of OS the original app is deleted and the new app installed, it is not simply laying one over the other, or updating the files of the previous version.
For this reason we have stopped updating Roon in our OS, as it seems to create issues for folks who have not performed a back up, and Roon manages this without the need for a re-install of the app, this is not available thru Signalyst.
As far as a HQPlayer back-up is concerned, I would of thought a simple insertion of licence or re-set of your settings would be way easier than faffing around with a back-up, its not like there are a million settings, just my thoughts.
Since AMSv4.2 was released, I do not have the possibility to digital output on my EX-P2. It is fixed on analog output ans digital doesn’t appear in choices menu.
How can I resolv this ?
Thanks in advance for your help
David Capture d’écran 2023-01-31 à 21.35.10|689x418
Yes - No change than before updating.
I’have tried on blue port and same issue.
I’have plugged EX directly on dac with USB and then USB XMOS appear in output menu but no sound while Roon play (Dac on usb Input) (?).
I have changed the USB cable and no result.
I have reboot several times all the network system etc…
Thanks in advance for our appointment
