K50 server is again not ripping
My K50 is again not ripping CDs.
Do we have again a similar issue as last year, where there was a simple bug in the Antipoides server SW and it took literally several weeks to fix?
Please refer to this thread: Unable to obtain meta - data for cd
Antipodes uses a third-party provider for metadata, and unfortunately, we have no control over the API availability
Hi Mark, 3rd party provider is understandable. But it’s still that the Antipodes product which is not working, right?
So is there a plan and a timeline for a fix?
Is there a possibility of ripping WITHOUT metadata? I am hoping that it will also mean a bit-perfect copy of the CD with no changes based on Internet- available versions, which I really dislike.
This malfunction has been causing troubles so I had remove my Melco D100 from Antipodes since last incident. Since then I connected it to my Mac and rip CD to AIFF via dbpoweramp. Better format / metadata editing, and most important - peace of mind. :laughing:
That said, I still hope Antipodes can offer simpler ripping function ,like without metadata and the options to choose format.
