Looking for some advice and direction on the power feed side of audio if possible.
With each step in other components upgrades and changes to date I have had noticeable improvements.
Presently I have an amp, DAC, K30 (S20 connected directly to the K30) components connected to a Construction RCD power box with a few different branded and DIY power cables.
Turntable and phono box wall warts on a seperate box connected to the same wall double power point as above.
Not perfect, although the sound is very good.
I have been mainly using the player function of the K30, thinking that an S60 for the S20 could be delayed until I start using the the Server and more power. Not sure if this theory holds
I don’t hear anything out of the ordinary with my mains as far as humming etc, so assume the power is at least reasonable, although this is not to say there is unheard noises making a difference.
I live Rural if this has any bearing.
Knowing all things matter with variable impacts, which should be the starting point and going forward over time into sorting or improving the power feed and ultimately the sound if possible.
Power box (filter- conditioner), power cables, etc?
[Updated]- Spreading the cost over time would the greater noticeable effect be to upgrade the power conditioner first, or the power cables first?
Recent research has many favourable reviews and recommendations for the Puritan PSM 136 and 156 along with the Ultimate power cords.
The other Power conditioner that has been recommended is the Keces (model IQRP-1500)?
Any recommendations greatly appriciated.
