Problems caused by new site update
myantipodes.com is not a “secure site”
You may need to allow connections to insecure sites
Thanks Mark, all good. I’ve other means to access for now. Just odd timing that today is when it stops being accessible on all my devices, and I also can’t access from the Setup tab at antipodes.audio which also worked consistently. [EDIT] Setup at antipodes.audio is accessible on my Mac, but not iPhone and iPad… still a no-go on all devices with myantipodes.com
SETUP is back and available on antipodes.audio
Issues, clear you browser cache and relaunch
My registration is once again shown on my Dashboard.
Something odd still in the works maybe… I am able to access my CX & EX via direct IP address, or when using the My Antipodes App on my iPhone / iPad. However, the myantipodes.com and https://antipodes.audio/setup sites do not show my CX & EX. (Pics attached.) Same results on my Mac, iPad, iPhone after browser cache cleared. Network has also been restarted.
Have you tried a different browser such as Google Chrome? The reason I ask is that whilst set-up was working yesterday with Safari (so long as Private Relay was turned off) it doesn’t today even after clearing the cache & cookies. However on trying Google Chrome my K50 was immediately detected & I experienced zero issues.
Hi Chili, sounds like you’ve been seeing a similar(ish) issue as I. I tested with Chrome just now. First I deleted my browsing history and then restarted Chrome. Same results though as with Safari for http://myantipodes.com and https://antipodes.audio/setup. I did also try using Incognito, but it was the same outcome… :face_with_diagonal_mouth:
I previously had experienced difficulties accessing my Dashboard via My Antipodes when using a VPN. Shutting off the VPN allowed me to access the Dashboard. I prefer not turning off the VPN, so I bookmarked the Dashboard web address and directly accessed it without issue with VPN engaged.
I encountered the same issue after rebooting Oladra, can’t access the dashboard via IP / myantipodes.com; still can ping server through router and play music via squeeze but can’t ping player. Neither server / player can be found on myantipodes.com
A post was split to a new topic: Dashboard Issue
