Looking at introducing the S20 into my system. My thoughts were connecting the S20 via usb from my nuc and then connecting the S20 via either I2S to my Mola Mola Tambaqui or alternatively using the Ethernet out from the S20 into the said DAC.
Can the S20 be used with a nuc running roon rock or would I require a S40 to connect to the S20 via USB?
Has the S20 been used in this way with a nuc and a Mola Mola Tambaqui?
Where I adopt the I2S approach, would I need a custom I2S cable?
I use the nuc loaded with roon rock to stream and this is connected via ethernet to the DAC.
I also have a PS Audio Directstream CD transport. The transport connects to the DAC via AES, which I propose to continue to use in this way.
Thanks in advance.
Doc
