I have set my time zone to somewhere that is currently 2am (Pangnirtung, sorry to wake all you guys). Lets see what happens.
Hi. Did not do any serious listening yet. Happy thatās is running. Although the GUI is not complete cannot access the initial page.
I just received the āupgrade is liveā email.
I changed the time zone to Buenos Aires, which changed my time zone to 2.30am. Got to 4.10am and no update info appeared
Iāve now changed it to San Juan time, 3.00am and will see if the update comes through this time.
@Carlos
Well done on the update.
Regards myantipodes from the website, it is likely that you have IPv6 enabled on your router, disabling this should kick myantipodes from our website back to life.
However, you still have full access to all features using myantipodes.com
If you use myantipodes.com you can access the Server Name / Time Zone / Functionality / Registered To these are available at the bottom of the Server and Player Dashboards
The software shutdown/reboot functionality has been removed in AMSv3.1.
Shutdown and reboot is performed via the front button.
There is no AMSv3.1 Manual, I believe what you are looking at is 3.0, that is no longer valid as all devices are moving to 3.1
Check the Guides out HERE
@MarkCole
Silly question, but when it asks for a reboot by pressing the front button (I have a K40) is it a long hold, i.e. 5+ seconds, or a quick press?
@Celts88
Long hold - 3 seconds should do it
Changing the timezone & waiting didnāt work for me either.
It didnāt work for me either. I set it back to my correct time zone. I will revisit tomorrow.
@Chilli
What server and software version are you on currently?
Itās a K50 & on version 3.0.
@Chilli
Ok, just relax, it will come
Should I set it back to itās regular time zone & just hope it comes tomorrow?
Iāve a K40 on version 3.0. Made sure I rebooted the K40 after each change of time-zone just to make sure.
Thatās twice Iāve changed the time zone and neither time itās worked.
Getting a bit worried something isnāt right ![]()
I rebooted mine after the time zone change too.
@Magnuska
Clear your browser cache and all will be revealed
You do realise that you have over 60 pages on the go there huh?
Ha ha , yeah, but that didnt work
Cleared my cache and have now changed to Winnipeg, which is just turning 3.00am now.
Iāve tried Chrome, Safari and Firefox, with all still showing AMSv3.0, so will wait until Winnipeg time 4.00am and see what happens.
