What is required to get HQ player to work on Roon with the K50
Glad to hear you got things working!
Your DAC appears to have I2S. This supports higher rates in both PCM and DSD than spdif. Since you are scaling using HQPlayer, this might be a good way to go.
I’m hoping to be able to use the i2s HDMI input on the Audio GD DAC. I’ve messaged @MarkCole with the AGD pin configuration, to find out whether it’s compatible with the K22. I’m assuming that the latter has dip switches somewhere, but I haven’t yet looked.
I am away from the office and don’t have access to my full resource regarding your pin configuration.
The dip switch is on the underside of the K22, dip switches are only used for DSD playback.
Plugging in the HDMI should give sound on standard PCM.
Hi Mark - thanks for the information. I don’t use DSD, and the HDMI connection worked fine for me this afternoon.
