Hi Mark, hang in there mate!
On a happy note, as a Roon user on my S30, I decided to try the Roon server/Squeeze player option as suggested by you in the past.
Too easy! Enable Squeeze support in Roon, one click in the Solution dropdown box and a quick auto-search for the S30 and it was playing.
Such a streamlined experience now.
I love it!
@MarkCole Strange thing on my EX this morning. Dashboard does not show any options. Refreshing once in awhile says no dac connected. ButâŚ. it is still configured as NAA (not squeeze as shown) and plays fine. Screen also shows that an update is available but canât connect to server.
Iâve rebooted several times, cleared browser cache, removed and replaced cable, powered done EX and dac but to no avail.
Toggling the âEnable Squeezebox Supportâ button off and on doesnât work in my setup. I actually have to choose another preset and then switch preset back to squeeze player with roon server. No problem but good to know for other users.
Changing the output had no change BUTâŚ. I was able to create a new preset first and then setup itâs player and server as I wanted. The default presets did not show up after, only my new preset. Iâll probably get Marc and co. to check it out tomorrow.
You cannot, you need to leave the server on overnight.
You can try and cheat the system by setting your timezone to somewhere close to 3am in the world and waiting.
Or book a appointment for remote access support and we can do it for you.
if updating a CX/EX is there a particular order in which it needs to be done?
Has there been any bug fix releases since the rollout? I see it is still offering me 4.0. If not, when is the first bug fix release planned?
I see that there is no longer any way to look at the Player dashboard before doing the upgrade. If I click âPlayer dashboardâ Then âUpgrade laterâ it shows me the Server dashboard, not the Player dashboard.
What is the status of the bug reported by Cereal Killer?
@andrewd I had a 1 -2- 1 session with Mark last week. They are now aware it isnt a user error and are working on the issue i rasied a few weeks ago. Basically the issue that needs fixing is; with the CX you canât turn the player software off in AMSv4 as you could with AMSv3xx - Mark said theyâll come back to me with a patch soon.
@andrewd
Updating, EX then CX
No bug fixes at this point, being worked thru.
As @cereal_killer mentioned we are working on the issue that affects CX.
However, the issue is only relevant if you have a CX in isolation, ie. using a CX only, if you are using a CX and EX in combination then it isnât really relevant, it is still there but not noticeable.
All Antipodes Servers are run as Server Player with AMSv4, the server service is off when set to none, the player services are off when apps set to none.
In a CX / EX combo, management of both is undertaken from the Solution Dashboard on the Player (EX)
In the Solution Dashboard, the server is set to CX, and a preset selected to set your server and player apps.
Management of the server is then undertaken from the server tab in the solution dashboard (EX)
Access of the CX dashboards via CX is not required at all, and are superfluous, via myantipodes.com
This is why access to myantipodes is from http://antipodes.online
If you require assistance, donât hesitate to make an appointment, and I can run the upgrade via remote.
